2 l3+ one connects the other doesnt
s4054378
Post by s4054378 » Fri Oct 06, 2017 4:18 pm
Just setting up my second l3+
copied settings across from my other l3.
but keeps coming up dead am i doing something wrong?
Thanks
Re: 2 l3+ one connects the other doesnt
Post by AppleMiner » Fri Oct 06, 2017 4:21 pm
Is your miner set as static or dhcp?
Try to flip it once to the other setting if you know how and reboot then re-find it on the network.
See if forcing a new IP will reconnect it.
s4054378
Post by s4054378 » Fri Oct 06, 2017 4:28 pm
one is static and one is dhcp, they both connect to nicehash as show in the picture
Post by AppleMiner » Fri Oct 06, 2017 4:32 pm
and the one that cant see prohash did you switch it to the other setting?
Under the network tab there is a diagnostics.
can you ping or traceroute to prohashing from both computers and see how that goes.
Can the one that sees it as DEAD ping it? Try to ping the proxy address, maybe its being blocked?
