Mining, But No Shares, Have I Setup Correctly?
Elixith
Post by Elixith » Tue Sep 26, 2017 2:24 pm
I'm new to mining and I just wanted to check if I have set everything up correctly, as I appear to be mining, detecting new blocks, but not accepting any shares, any help and support would be much appreciated, see my log below:
This is version 2014-02-28 (beta)
based on pooler-cpuminer 2.3.2 (c) 2010 Jeff Garzik, 2012 pooler
Cuda additions Copyright 2013,2014 Christian Buchner
LTC donation address: LKS1WDKGED647msBQfLBHV3Ls8sveGncnm
BTC donation address: 16hJF5mceSojnTD3ZTUDqdRhDyPJzoRakM
YAC donation address: Y87sptDEcpLkLeAuex6qZioDbvy1qXZEj4
[2017-09-26 18:52:02] 2 miner threads started, using 'scrypt' algorithm.
[2017-09-26 18:52:02] Starting Stratum on stratum+tcp://prohashing.com:3333
[2017-09-26 18:52:06] Stratum detected new block
[2017-09-26 18:52:06] GPU #0: GeForce GTX 1050 Ti with compute capability 6.1
[2017-09-26 18:52:06] GPU #0: the 'T' kernel ignores the texture cache argument
[2017-09-26 18:52:06] GPU #0: interactive: 1, tex-cache: 0 , single-alloc: 1
[2017-09-26 18:52:06] GPU #0: 32 hashes / 4.0 MB per warp.
[2017-09-26 18:52:06] GPU #1: GeForce GTX 750 Ti with compute capability 5.0
[2017-09-26 18:52:06] GPU #1: the 'T' kernel ignores the texture cache argument
[2017-09-26 18:52:06] GPU #1: interactive: 1, tex-cache: 0 , single-alloc: 1
[2017-09-26 18:52:06] GPU #1: 32 hashes / 4.0 MB per warp.
[2017-09-26 18:52:07] GPU #0: Performing auto-tuning (Patience...)
[2017-09-26 18:52:07] GPU #0: maximum total warps (BxW): 747
[2017-09-26 18:52:09] GPU #1: Performing auto-tuning (Patience...)
[2017-09-26 18:52:09] GPU #1: maximum total warps (BxW): 752
[2017-09-26 18:52:10] Stratum detected new block
[2017-09-26 18:52:29] Stratum detected new block
[2017-09-26 18:52:57] Stratum detected new block
[2017-09-26 18:53:15] GPU #1: 273558.83 hash/s with configuration T10x20
[2017-09-26 18:53:15] GPU #1: using launch configuration T10x20
[2017-09-26 18:53:15] GPU #1: GeForce GTX 750 Ti, 172.51 khash/s
[2017-09-26 18:53:32] Stratum detected new block
[2017-09-26 18:53:32] GPU #1: GeForce GTX 750 Ti, 263.48 khash/s
[2017-09-26 18:53:51] Stratum detected new block
[2017-09-26 18:53:51] GPU #1: GeForce GTX 750 Ti, 263.47 khash/s
[2017-09-26 18:53:52] GPU #0: 375152.65 hash/s with configuration T24x12
[2017-09-26 18:53:52] GPU #0: using launch configuration T24x12
[2017-09-26 18:53:52] GPU #0: GeForce GTX 1050 Ti, 229.79 khash/s
[2017-09-26 18:54:31] GPU #0: GeForce GTX 1050 Ti, 358.64 khash/s
[2017-09-26 18:54:42] Stratum detected new block
I just continue to see notifications of the hash rate and new blocks detected.
Here is my bat file cmd:
cudaminer.exe -o stratum+tcp://prohashing.com:3333 -u Elixith -p n=elixith1 -i 1 -l auto -C 1 -m 1 -H 2
Any ideas?
micca410evo
Re: Mining, But No Shares, Have I Setup Correctly?
Post by micca410evo » Tue Sep 26, 2017 5:35 pm
try another pool which accepts low difficulty, my knowledge is PH isn't accepting difficulty under 4096 or even 8192.
Elixith
Post by Elixith » Tue Sep 26, 2017 5:39 pm
Thank you, I will give that a go, any recommendations for low difficulty pools?
micca410evo
Post by micca410evo » Tue Sep 26, 2017 5:43 pm
Elixith wrote:Thank you, I will give that a go, any recommendations for low difficulty pools?
What do you want to mine with those GPU's? for good GPU mining profitability i would say Nicehash
Post by Steve Sokolowski » Tue Sep 26, 2017 5:49 pm
Elixith wrote:Hi,
Any ideas?
These miners are mining normally and are working great. However, GPUs are so unprofitable that it's unlikely you'll find a share more than once an hour.
You can still use GPUs to mine here, but you'll lose a lot of money. Instead, I recommend that you select an Ethereum mining pool, where you'll be able to earn more.
