L3+ Miners disconnecting frequently today
deltasniper73
Post by deltasniper73 » Tue Aug 15, 2017 3:55 pm
My miners are disconnecting to PH every 20-30 mins, several others (on the forums and the slack channel) have also mentioned that they are suffering from this disconnect problem today (8/15/17)
Thanks
DS
MglMogul9
Re: L3+ Miners disconnecting frequently today
Post by MglMogul9 » Tue Aug 15, 2017 4:02 pm
I noticed this today as well. Was wondering what was going on. lol
fernip0w
Post by fernip0w » Tue Aug 15, 2017 4:03 pm
Ditto, Mine have been disconnecting on and off...at least I have a backup pool set...hate to mine litecoins though lol
Jalapan
Post by Jalapan » Tue Aug 15, 2017 4:05 pm
same.
i also noted that the earnings tab with found blocks dont match blocks found that antminer reports... not sure if issue is connected.
glccom
Post by glccom » Tue Aug 15, 2017 4:28 pm
Yep they have something hosed up.
ru55ian
Post by ru55ian » Tue Aug 15, 2017 4:30 pm
all my L3+ miners are today actually more stable than usual... not sure why but whatever it is, impacting my miners positively
r1979
Post by r1979 » Fri Aug 18, 2017 3:17 am
ru55ian wrote:all my L3+ miners are today actually more stable than usual... not sure why but whatever it is, impacting my miners positively
yep, I noticed the same on August 15, I can't say the same about yesterday and the day before yesterday (August 16 and 17).
