How can I solve this issue :
"This miner is submitting shares too frequently. Its static difficulty is too low, and therefore is being ignored."
Thanks
Best
L3+ is submitting shares too frequently
Re: L3+ is submitting shares too frequently
best set your static diff to 131072 by adding "d=131072" to your password. this is the best performing difficulty for L3+
Going to test 131072. I personally had the best results with 20-50kGregoryGHarding wrote:best set your static diff to 131072 by adding "d=131072" to your password. this is the best performing difficulty for L3+
- CritterDog
I was using 32768 on my L3+ no problem until today the pool says thats not enough and started ignoring my shares I am trying 65536 nowvhmanu wrote:Going to test 131072. I personally had the best results with 20-50kGregoryGHarding wrote:best set your static diff to 131072 by adding "d=131072" to your password. this is the best performing difficulty for L3+
is this permanent or do i need to change that difficulty number?GregoryGHarding wrote:best set your static diff to 131072 by adding "d=131072" to your password. this is the best performing difficulty for L3+
And would this earn me more profitability with an l3+ then having the difficulty automatic?
131072 is the best diff for L3+, you can try anything between 65K and 131K if you like
And would this earn me more profitability with an l3+ then having the difficulty automatic?GregoryGHarding wrote:131072 is the best diff for L3+, you can try anything between 65K and 131K if you like
difficulty does not change profitability, only how long it takes to solve a share, some miners have better consistent hashrate with specific difficulties.
I see..so l3+ would be better with a static diff? And would i need to change it depending on any factor or can i leave it at 131k ?GregoryGHarding wrote:difficulty does not change profitability, only how long it takes to solve a share, some miners have better consistent hashrate with specific difficulties.
The average mining efficiency is quite low with d=131k. around 90%.
The hashrate is less stable ass you can see :
http://imgur.com/a/8NA2w
I will probably try a lower value soon.
What do you think ?
What do you think ?
