Live Worker Status page showing 0 miners connected
georgiaturtle
Post by georgiaturtle » Thu Jul 20, 2017 5:31 pm
Live worker status page showing no miners connected while miner status shows connected to pool by 100% discarded shares.
megaquake
Re: Live Worker Status page showing 0 miners connected
Post by megaquake » Thu Jul 20, 2017 5:39 pm
Yes and all my shares are being rejected, the pool should disconnect the miner so we are not loosing income, my advice is to use an alternative pool like I did
georgiaturtle
Post by georgiaturtle » Thu Jul 20, 2017 9:18 pm
Yeah. I moved right after I posted this. This used to be a good pool until code changes started back last year. No longer dependable.
Site Admin
Post by Chris Sokolowski » Fri Jul 21, 2017 2:09 am
If the pool is accepting shares, then they will be counted, but it may take a few minutes to write them to the database and credit your account if the share writing is delayed as shown on the homepage. In addition, if the pool's shares are delayed, then the live worker stats will also be delayed, in which case there would be the same delay between when you connect the miner and when it shows up in the stats. We are working to increase capacity, but for now there will be times where shares will be delayed. All earnings will be counted though.
tabak6
Post by tabak6 » Sat Jul 22, 2017 4:11 am
Hello, does not work live balance
