After X11 mining implementation, scrypt mining with difficulty set to d=512 not working anymore.
Regards
Password configs not working anymore
- Chris Sokolowski
- Site Admin
Re: Password configs not working anymore
Do you have the miner directly connected to the site or are you using an intermediate like NiceHash or MiningRigRentals?
- CritterDog
Static is not working for my Script miners also
I can confirm this issue when using nicehash for both scrypt and X11.
Tested for scrypt with verificator:
Using: Pool pass: d=8192
Response from verificator: Received mining.set_difficulty... OK: difficulty=4096
When mining the miner disconnects after a short while because of too low difficulty.
Best,
Maznoz
Best,
Maznoz
I had the same problem until I added a=scrypt to the password arguments. Seems like when it defaults to scrypt it always uses the dynamic difficulty.
Thanks. Confirmed for scrypt that after adding an explicit "a=scrypt" the difficulty is properly picked up by the pool.
That worked for me! Many thanks! spauk Thanks for sharing!spauk wrote:I had the same problem until I added a=scrypt to the password arguments. Seems like when it defaults to scrypt it always uses the dynamic difficulty.
Regards xichas
Brilliant, does indeed work!
