A few customers recently have noticed that MiningRigRentals users are intermittently unable to connect. The cause of this problem is that MiningRigRentals uses a single IP address for all of their rentals, and they allow their customers to send as many invalid authentication requests as they would like to the system. Anyone can rent hashrate from MiningRigRentals and improperly configure it, causing thousands of invalid authentication requests per minute and resulting in a temporary ban of the IP address.
There are three solutions to this problem. If you are directing your own miners through MiningRigRentals, the preferred solution is to directly mine here. That will result in lower latency and higher profits anyway. If you are renting from MiningRigRentals, you can set up a proxy server on a different IP address, and that will allow us to differentiate your traffic from the improper rentals. Finally, you can rent from NiceHash instead, as NiceHash prevents too many invalid authentication attempts.
We apologize for this issue. Unfortunately, we can't unblock or adjust the ban threshold, as the threshold is needed to prevent CPU overload from reducing profits for other customers.
Thanks,
-Steve
Note about MiningRigRentals
Re: Note about MiningRigRentals
What happened to your profitability? Your yield has become very low!!!! It is even lower than rent from Nice Hash!!! Accordingly, your overall hashrate goes down!!!
Yes, and they always have a problem with the shares or something. And steve said they solved the problem. But i lost a half day and they didnt get anything. I am seriously considering to change to another pool.hikan2 wrote:What happened to your profitability? Your yield has become very low!!!! It is even lower than rent from Nice Hash!!! Accordingly, your overall hashrate goes down!!!
NiceHash can often have good profitability on days when there are coins that are not listed on exchanges and those coins have low difficulty. Sometimes, people are willing to pay a lot more than the going rate to rent hashpower and direct it at those coins, in the hopes that someday they will be worth something.hikan2 wrote:What happened to your profitability? Your yield has become very low!!!! It is even lower than rent from Nice Hash!!! Accordingly, your overall hashrate goes down!!!
Unfortunately, this isn't true all of the time, only when there are new coins available, so the key is being an insider and knowing when someone is going to release a coin and pre-mine it this way.
There are a few miners with low hashrate who, because of the low number of shares they submit, may have received less than what they would expected simply due to poor luck. GPU and CPU miners are some examples. If you're one of those affected, please submit a support ticket and Chris will see if a one-time one-person exception can be made for you.jpuche27 wrote:Yes, and they always have a problem with the shares or something. And steve said they solved the problem. But i lost a half day and they didnt get anything. I am seriously considering to change to another pool.hikan2 wrote:What happened to your profitability? Your yield has become very low!!!! It is even lower than rent from Nice Hash!!! Accordingly, your overall hashrate goes down!!!
Steve, i submited support ticket because my the problems i had on sunday but i am waiting for a answer from chris. I think it is very rude from you. And today you have a problem with profit update?? Or will i lose again??Steve Sokolowski wrote:There are a few miners with low hashrate who, because of the low number of shares they submit, may have received less than what they would expected simply due to poor luck. GPU and CPU miners are some examples. If you're one of those affected, please submit a support ticket and Chris will see if a one-time one-person exception can be made for you.jpuche27 wrote:Yes, and they always have a problem with the shares or something. And steve said they solved the problem. But i lost a half day and they didnt get anything. I am seriously considering to change to another pool.hikan2 wrote:What happened to your profitability? Your yield has become very low!!!! It is even lower than rent from Nice Hash!!! Accordingly, your overall hashrate goes down!!!
Steve,
In regards to MRR, is there a way to direct machines to owned Machines via MMR to PH through a Proxy to establish a differentiation from the Invalid Shares?
Will simply setting the proxy stratum in the help do the trick? proxy.prohashing.com:443
why bother, no one cares.
You'll need to set up your own proxy server. We can't offer a public server because then whoever is abusing their service will simply direct the miners at the proxy server, and get the proxy server banned.DuncanBoaz wrote:Steve,
