Second mining server now available
Contact:
Postby Steve Sokolowski » Wed Dec 06, 2017 8:15 am
I'm pleased to announce that our first parallel mining server is now running, two months ahead of schedule.
Parallel mining is completely transparent to customers. You can connect using port 3333 as normal, and you will be assigned at random to one of the servers. All servers run identical code and average out to the same profit over the course of the day, and they communicate with each other to make sure that coins are not overassigned.
The number of connections is now limited to 16,000. If we reach that today and there are no problems, then we will add a third mining server tonight, and a fourth after that, for existing customers. If suppressed demand is so high that more than 32,000 miners want to mine with us, then Chris will need to order and install more hardware before we can open registrations.
Feel free to make any comments, and thanks for your patience while we worked on this improvement!
Thanks,
-Steve Sokolowski
bsock
Re: Second mining server now available
Postby bsock » Wed Dec 06, 2017 9:36 am
Just so I'm clear, and many thanks for all the improvements, are there any adjustments we need to make to the config on our miners such as L3+? Or will it treat the pool entry in the configuration as two "separate" mining pools? Thanks.
Contact:
Postby Steve Sokolowski » Wed Dec 06, 2017 9:39 am
Customers won't even know that there are actually two servers running in parallel. Just continue to connect to the existing ports, and new connections are randomly distributed between the two servers.
bsock
Postby bsock » Wed Dec 06, 2017 9:40 am
Thanks! Keep up the great work!
Who is online
Users browsing this forum: No registered users and 2 guests
