[ANN][BETA] KOINPRO.com Bitcoin Exchange - Fast, secure, and built for winners
Announcements and discussion of products and services.
KoinPro
Post by KoinPro » Tue Feb 04, 2020 9:51 am
Image            Image
        Start Trading    Learn to Trade    Affiliate Program    Help
                                                              About Us    Privacy Policy    Terms & Conditions    Contact Us
                                                            Image    Image    Image    Image
KoinPro
Re: [ANN][BETA] KOINPRO.com Bitcoin Exchange - Fast, secure, and built for winners
Post by KoinPro » Mon Mar 23, 2020 7:39 am
💹 Trade Stocks with Bitcoin at KoinPro 💹
Discover a new article about KoinPro at our blog:
https://medium.com/koinprocom/trade-sto ... 346cac5f9a
KoinPro
Post by KoinPro » Fri Apr 10, 2020 11:22 am
📉 BTC/USD Intraday:
The RSI is oversold. The downside prevails as long as 7385 is resistance. Expect 6572 and 6400.
📈 Alternative scenario:
The upside breakout of 7385 would call for 7684 and 7862.
⚠️ The RSI is trading below 30. This could mean that either the pair is in a lasting downtrend or just oversold and that therefore a rebound could shape (look for bullish divergence in this case). The MACD is negative and below its signal line. The configuration is negative. Moreover, the pair is trading under both its 20 and 50 MAs (respectively at 7251 and 7284). Finally, the Bitcoin / Dollar has penetrated its lower Bollinger band (7092).
KoinPro
Post by KoinPro » Wed Apr 15, 2020 1:51 pm
📉 BTC/USD Intraday:
the downside prevails as long as 7076 is resistance
above 7076, look for 7363 and 7533.
⚠️ the RSI is below its neutrality area at 50. The MACD is below its signal line and negative. The configuration is negative. Moreover, the pair stands below its 20 and 50 MAs (respectively at 6884 and 6891).
KoinPro
Post by KoinPro » Thu Apr 16, 2020 1:54 pm
📈 BTC/USD Intraday:
rebound towards 7144.
📉 Alternative scenario:
below 6407, expect 6130 and 5965.
⚠️ the RSI is below its neutrality area at 50. The MACD is above its signal line and negative. The configuration is mixed. Moreover, the pair stands below its 20 and 50 MAs (respectively at 6659 and 6744).
More predictions: https://t.me/koinproNews
KoinPro
Post by KoinPro » Fri Apr 17, 2020 10:36 am
📈 BTC/USD Intraday:
as long as 6842 is support, look for 7613
below 6842, expect 6546 and 6370.
⚠️ the RSI is above 50. The MACD is positive and below its signal line. The pair could retrace. Moreover, the pair is above its 20 and 50 MAs (respectively at 7079 and 7058).
KoinPro
Post by KoinPro » Mon Apr 20, 2020 5:18 pm
If you're new to KoinPro and KOI token, you may refer to the video below for more information:
https://youtu.be/aBeRml8X6d0
KoinPro
Post by KoinPro » Tue Apr 21, 2020 1:12 pm
📈 BTC/USD Intraday:
rise from 5271. Expect 9308 & 10501.
the downside breakout of 5271 would call for 3293 and 2115.
⚠️ the RSI is below 50. The MACD is above its signal line and positive. The break above the 50 area on the RSI would call for further upside. Moreover, the pair is trading under its 20 MA (6983) but above its 50 MA (6840).
KoinPro
Post by KoinPro » Wed Apr 22, 2020 5:53 pm
📈 BTC/USD Intraday:
the upside prevails as long as 6862 is support. Expect 7465 and 7642.
the downside breakout of 6862 would call for 6565 and 6389.
⚠️ the RSI is trading above 70. This could mean that either the pair is in a lasting uptrend or just overbought and that therefore a correction could shape (look for bearish divergence in this case). The MACD is above its signal line and positive. The configuration is positive. Moreover, the pair is trading above both its 20 and 50 MAs (respectively at 6950 and 6902). Finally, the Bitcoin / Dollar has crossed above its upper Bollinger band (7052).
KoinPro
Post by KoinPro » Tue Apr 28, 2020 12:36 pm
🔶💹 CHECK OUT OUR LATEST ARTICLE AT HACKERNOON 💹🔶
https://hackernoon.com/how-does-our-exc ... y-ni6732xh
