naming miners
Doug11
naming miners
Post by Doug11 » Thu Jun 20, 2019 2:18 pm
! have 7 antminers. 2 L3+ and 5 L3++ All are up and running in 3 different locations except for 1. The setup tutorial ! found said to put a name on each. ! did that, but all ! get is a random string of characters on Prohashing and those seem to change fairly often. How do ! change the names on each so ! can have a clue which is not running or hashing without driving across town?
Also, ! found one yesterday that had the "fault" light on. ! shut it off and restarted it. What causes that error?
Re: naming miners
Post by Steve Sokolowski » Wed Nov 06, 2019 9:24 am
Doug11 wrote: Thu Jun 20, 2019 2:18 pm ! have 7 antminers. 2 L3+ and 5 L3++ All are up and running in 3 different locations except for 1. The setup tutorial ! found said to put a name on each. ! did that, but all ! get is a random string of characters on Prohashing and those seem to change fairly often. How do ! change the names on each so ! can have a clue which is not running or hashing without driving across town?
You should use the "n=" password argument to set a unique name for each miner. That will allow you to determine which miner is causing the problem if one of the miners has an issue. If you use the same "n=" worker name for two or more miners, then they will have red borders around their boxes in "live worker status" and they will all have the random names that you're seeing.
In regards to the fault light, that's a hardware problem that's not related to Prohashing. The best place to figure out the answer to your question is to contact the manufacturer. With the miners I have, the fault light often indicates that one of the boards in the miner is failing, which means that the failing board needs to be bypassed and the hashrate of the miner will be lower. However, that's only my miners, and you'll have to talk to the manufacturer or read the instruction manual for your specific miner to figure out more about your specific problem.
Jameslibon
Re: naming miners
Post by Jameslibon » Wed Dec 30, 2020 11:51 am
Steve Sokolowski wrote: Wed Nov 06, 2019 9:24 am
Thanks for this piece of information. I also had the same issue. I'll try this out and see if it will work
