Ehash/claymore rig setup
keksik
Post by keksik » Sat Sep 01, 2018 3:24 pm
Hi guys,
i have issue to connect my rigs to prohashing server. have tried to use this commands via claymore:
EthDcrMiner64.exe -epool stratum+tcp://prohashing.com:3339 -ewal myPHlogin -epsw n=rig1 -allcoins 1 -allpools 1 -platform 1
also tried many variations and still gettign same error message.
ETH: Stratum - Connected (prohashing.com:3339) (unsecure)
ETH: Authorization failed
: {"id":2,"result":null,"error":[-3,"Method'eth_submitLogin'notfoundforservice'mining'",null]}
ETH: Job timeout, disconnect, retry in 20 sec...
any advice?
thanks
Re: Ehash/claymore rig setup
Post by CSZiggy » Sat Sep 01, 2018 3:58 pm
What happens if you just try:
without the other parameters?
and I am guessing the myPHlogin is the username you use on the prohashing.com site not here on the forums.
keksik
Post by keksik » Sat Sep 01, 2018 4:12 pm
i have already tried this option with same results and yes i have two username and tried both, of course first was on webpage not the forum.
Post by Steve Sokolowski » Sat Sep 01, 2018 5:09 pm
keksik wrote:Hi guys,
any advice?
thanks
We use the "NiceHash stratum" protocol. There is an older "getWork" protocol which we don't support. The command that works for me is:
EthDcrMiner64.exe -epool stratum+tcp://prohashing.com:3339 -esm 3 -ewal testuser1 -allpools 1
keksik
Post by keksik » Sat Sep 01, 2018 5:40 pm
Finally i can confirm with above config im able to mine without any issue. also can add more parameters, such as:
-platform 1 -mode 1 -epsw rig1. I have not tried any others,but it should be working as well.
citronick
Post by citronick » Sat Sep 01, 2018 7:01 pm
Anyone tried configuring an Bitmain E3 to work?
LMC
Post by LMC » Sun Sep 02, 2018 1:50 am
citronick wrote:Anyone tried configuring an Bitmain E3 to work?
I tried for hours, both direct and through a proxy. I've given up.
Either it just shows up dead and stays that way, or, thru MRR I can get some settings to work, but it never shows a hashrate (through the MRR console). On PH, it just creates hundreds of ghost miners, never stays connected long enough to show a hashrate.
Anyone get the E3 to work here?
citronick
Post by citronick » Sun Sep 02, 2018 2:12 am
Steve said that Nicehash stratum is currently supported - which is -esm 3 Claymore speak.
I think we need get work type mining support like ethminer - perhaps PH can consider adding this support.
https://github.com/ethereum-mining/ethminer
That will get most miners using Claymore and non-Claymore miners out there... I think there is no dev fee in ethminer
If X3 cant work with NH, I have little confidence E3 can work....
Post by Steve Sokolowski » Sun Sep 02, 2018 7:09 am
citronick wrote:Steve said that Nicehash stratum is currently supported - which is -esm 3 Claymore speak.
Do you know if there is a proxy server that can convert between the two protocols? Using the old "getWork" protocol would require a significant amount of time to implement. That way, we could focus on other algorithms, while using proven code for supporting both on Ethash.
PolakCrypto
Post by PolakCrypto » Mon Sep 03, 2018 12:43 am
Whats a "solid" working bat line for ethminer, what im using and keep getting disconnected with?
I just saw your Claymore string above and tried it with -esm 3 and some adjustments and finally got connected. Going to test claymore and see if I get disconnected.
Also does static difficulty d= argument work or is it disallowed for now?
EDIT: I got claymore working but it still disconnects for me after mining for a bit on a static coin(some cards cant handle higher size dag files in my rig so I set a static coin to mine). Then when it reconnects, if it does, it fails to mine cause of the dag size aka it wont reconnect and mine my selected static coin.
Probably just a few bugs to work out yet for EThash. Tried for last hour or so and itll mine for 5 minutes sometimes, 15 minutes, i think my best was 45 minutes then it started acting up/disconnecting.
