Is it a solo?
konstruktor44
Is it a solo?
Post by konstruktor44 » Sun Mar 04, 2018 11:12 am
Hello
in L3 + indicated
but it's not a solo
it works as always
URL prohashing.com:3333
Worker konstruktor44
Password <<c=Digibyte m=solo>>
konstruktor44
Re: Is it a solo?
Post by konstruktor44 » Sun Mar 04, 2018 11:26 am
changed the parameters
Password "c = Digibyte m = solo"
konstruktor44
Re: Is it a solo?
Post by konstruktor44 » Sun Mar 04, 2018 1:24 pm
konstruktor44
Re: Is it a solo?
Post by konstruktor44 » Sun Mar 04, 2018 1:44 pm
Re: Is it a solo?
Post by CSZiggy » Sun Mar 04, 2018 2:04 pm
5th times the charm?
c=digibyte m=solo
no quotes, no spaces before or after the =. just that ^^^^ paste that line in.
konstruktor44
Re: Is it a solo?
Post by konstruktor44 » Sun Mar 04, 2018 3:36 pm
what's wrong?
more details, please
Re: Is it a solo?
Post by CSZiggy » Sun Mar 04, 2018 3:44 pm
It appears to be a typical ID-ten-T error.
URL: prohashing.com:3333
WORKER: konstruktor44
PASSWORD: c=digibyte m=solo
Just put those in.
And use POOL1, otherwise pool1 may be doing something else and never get to POOL2's settings.
konstruktor44
Re: Is it a solo?
Post by konstruktor44 » Sun Mar 04, 2018 4:34 pm
friend
Thank you
all perfectly
tell me how to add a new coin that is not listed
konstruktor44
Re: Is it a solo?
Post by konstruktor44 » Sun Mar 04, 2018 4:35 pm
bypassing the pool somebody tries to rock into solo
mycide
Re: Is it a solo?
Post by mycide » Sun Mar 04, 2018 4:52 pm
konstruktor44 wrote:friend
Thank you
all perfectly
What do you mean? You cant add a coin to Prohashing that is not already listed here.
if you want to check, use the explorer link on main page and find the coin you wish to mine, if its not there you cant mine it at PH, it will also provide you with the name to enter in coin=
