Connecting to the pool problems
ryang1607
Post by ryang1607 » Tue Dec 19, 2017 7:58 am
I have got 6 Antminer L3+ and 2 D3 miners that I am struggling to connect to the pool.
I am using the following details to try and connect:
URL - stratum+tcp://prohashing.com:3333
Worker - ryang1607.001
Password - n=ryang1607
Can anyone point me in the right direction to what I am doing wrong and what I need to do in order to connect please...
Thanks
greaseman316
Re: Connecting to the pool problems
Post by greaseman316 » Tue Dec 19, 2017 7:59 am
URL prohashing.com:3333
worker user name used to log in
password a=x11 n=wkr1 or a=x11 d=128 n=wkr1
for D3s
ryang1607
Post by ryang1607 » Tue Dec 19, 2017 9:17 am
Thank you, I will give that a go and see what happens.
Do you know about the L3s?
greaseman316
Post by greaseman316 » Tue Dec 19, 2017 11:28 am
i do not know personally but pass word line should only be n=wkr1
appleminer can tell you more he has L3s and can tell you better but that should get you started
Post by AppleMiner » Tue Dec 19, 2017 12:10 pm
so when you log into prohashing your username on the site is ryang1607.001 ???
Or are you adding the .001 at the end?
The username should only be the username you used when you sign into the prohashing.com website, nothing added.
The period in your username scares me for some reason.
Good Luck!
HAPPY HASHING
ryang1607
Post by ryang1607 » Tue Dec 19, 2017 3:26 pm
AppleMiner wrote:so when you log into prohashing your username on the site is ryang1607.001 ???
Good Luck!
HAPPY HASHING
When I log in, my username is ryang1607 but I have added the .001 and .002 etc for each indiviual worker.
Should I leave this off and can you confirm what password I need to enter please?
Foxx
Post by Foxx » Tue Dec 19, 2017 3:39 pm
yes, ryang. you need to use use your login name as the 'worker' name. any alteration to that and it will not load into your account.
to differentiate you need to put the worker number in your password, such as, n=worker1
you might also want to specify the algo so you would use a=x11 n=worker1 if your running the x=11 algo.
