First D3 plugged in alongside L3+ that have been mining well. Connected successfully, reset to change password configuration, now getting only socket connect refused.
Is there some issue with X11 pool connectivity that is known? Is there some reset/reboot procedure I need to adhere to for this pool?
D3 Socket Connection Refused
Re: D3 Socket Connection Refused
did you read the help page??? need more info!!!!! what password arguments are you using????
Only arguments - n=workername a=x11
The worker connected successfully.
We changed antminer-configured password - reset the box using software reset. Will not reconnect.
ok try this a=x11 d=256 n=wkr1
sometimes there are issues when reconnecting the difficulty goes stupid and wont let you connect
No change with d=256
In Help I see:
"One of the limitations of the protocol is that while it can receive work from many miners on a single connection, it cannot direct work to those miners individually. When work is sent to a single Stratum connection, all mining rigs and all users authorized on the connection are required to accept the new work. Because of this limitation, password arguments must be consistent across all miners on a single connection. Arguments may, however, differ between miners with the same user account, provided they are not mining on a single connection."
Is this any part if my issue? Connect them to different server port maybe...?
In Help I see:
ok in miner config set it just like this ok
URL prohashing.com:3333
worker is the same login you use to see live earnings
password a=x11 d=256 n=wkr1
this should work fine no issues
just hit save and apply at bottom right and you good to go
