GPU Ethash Static Diff Issue
Just wondering why both my GPU rigs has been set to a static difficulty of .25 (1.07gig) for the last 20 days. I have not changed any setting, command lines or software. I have restarted both and tried using a different software with the same results. Both rigs are connected to port 3339 and using Ethash algo. Before this happened the difficulty rate would range from 1.07 to 17gig. I am aware that the profit is the same just wondering with the change? Thanks.
- Contact:
Re: GPU Ethash Static Diff Issue
An incorrect implementation was discovered and corrected. Ethash, as an algorithm, doesn't work with variable difficulty.Raven2323 wrote: ↑Tue May 24, 2022 12:31 pm Just wondering why both my GPU rigs has been set to a static difficulty of .25 (1.07gig) for the last 20 days. I have not changed any setting, command lines or software. I have restarted both and tried using a different software with the same results. Both rigs are connected to port 3339 and using Ethash algo. Before this happened the difficulty rate would range from 1.07 to 17gig. I am aware that the profit is the same just wondering with the change? Thanks.
Thank you. I have spoke with Steve as well. Everything is good now. Appreciate the information.
The "GPU Ethash Static Diff Issue" refers to a problem encountered by GPUs while mining cryptocurrencies using the Ethash algorithm. This issue can cause fluctuations in mining difficulty, affecting mining efficiency and profitability. Miners experiencing this problem may need to adjust their mining settings or seek assistance from technical support.
For those in South Africa, looking to Buy Ozempic Online South Africa, ensure to explore reputable online pharmacies and consult with a healthcare professional before making any purchase.
The "GPU Ethash Static Diff Issue" affects mining efficiency and profitability, requiring miners to adjust settings or seek technical support. Additionally, for those in South Africa seeking to Buy Ozempic Online, consult reputable online pharmacies and healthcare professionals before purchasing.
